R23 Dual Radio replacement suggestions
CruisingElvinRay":17xi3i5d said:
Where did you put the black box? Looks good!
The black box is 6-1/8" x 2-3/8" x 3-11/16" and I was able to mount it under and to the right of the Chartplotter when facing from the rear. There was plenty of room, just a tight space to work and awkward angle to install. There are 6 plugs that go into the box (Antenna, NMEA, Remote Head Unit, Aux Harness, power/Speaker Harness and USB)
I made a trim piece out of plexiglass and covered it with leather furniture tape
Wow, looks great!. Where did you get the leather furniture tape?
simonp":rue49h9u said:
I upgraded the Dual head unit to a Rockford Fosgate, paid $340
https://www.amazon.com/dp/B0108LNLBK
I do prefer the square form factor over the round one, the sound quality is better and it puts out more power. The menu system is easier to navigate too.
I also replaced the cabin speakers with these Polks
https://www.amazon.com/gp/product/B00378KMF0
Hello!
On your head unit upgrade from the Dual, did you need any sort of new wiring harness on the install? Or was it "plug and play"?
Thanks!
Hello,
I have the Dual MGH37BT on my 2021 R25. My cockpit speakers suddenly stopped working while cabin worked. I verified speakers and wiring were ok. I then contacted Dual Radio manufacture (866-382-5476) who suggested resetting the radio by pressing the squares and backtrack buttons at same time and this worked! All good now.
Hope this helps.
ftornabe":wawauo3w said:
...resetting the radio by pressing the squares and backtrack buttons at same time...
This is a great tip! I have the Dual MGH25BT and the Bluetooth had stopped working. It just wouldnt pair with any device any more. I was researching replacement units and then saw this tip and rushed out to my boat to try it. Three seconds later, I saw the 'EPROM RESET' message and when I turned the unit back on, Bluetooth worked again! Saved me $300 =)
I finally contributed something to the website! 🙂
I have the fusion UD -750 with the worthless little phone tray. After doing some research it looked like the MS-ARX70 would work with this radio. It does not pare. Further research says they are not compatible. Does anyone know of a remote that works with the UD750? Its on the other side of the helm and a PITA to adjust the volume when underway. Mine is a 2016 25SC
You should be able to control your UD750 from the Garmin MFD at the helm. On my GPSMap I go to menu/data bars/media Bar On.
We went with the following. It was pretty much plug and play. Works great and no noised from the fan.
Planet Audio PGR35B Weatherproof Marine Gauge Receiver - Bluetooth, Digital Media MP3 Player, No CD Player, USB Port, AUX-In, AM/FM Radio Receiver. Purchased on Amazon $120.
