rick&sue
- Feb 5, 2014
- C-248 C
- FMLT2506J607
- POPEYE
I'm a newbe R25 (early 2007) owner and am trying to figure out the bilge pump arrangement. This boat has one Rule 1100GPH pump in the sump under the drive shaft with a float switch. It has 4 additional shallow sumps (two are under the black water tank) aft of the shaft that have drain tubes in them allowing the water to eventually end up in the sump under the shaft. I'm not comfortable with one small pump. I can't find any other pumps or discharge holes. It appears that the Rule 2000GPH pump is too big in diameter to fit in the bottom of the shaft sump.I would sure be interested in finding out what other older model R25's have for bilge pumps. Thanks!!
