My 2011 R-25 with a Yanmar 4BY2-150 has developed a minor fuel puzzle.
As I travel, the digital "fuel in tank" reading on the Garman always agreed closely with my pencil and paper calculations of the fuel using the burn rate * hours run. When it came time to refill, the fuel added agreed closely with the total - "fuel in tank" reading. Both these readings agreed closely with the fuel guage present on several of the information/engine screens. All was golden.
When I topped off the tank and pressed the "add fuel to tank" button, the "fuel in tank" digits agreed with my setting of maximum fuel and the analog gauge "snapped" from the level before the fill-up to full. This led me to believe the analog gauge was just a synthetic fuel gauge run off the "fuel in tank" calculation.
This was confirmed by another discussion on this board that said the generator consumption was not measured by the "fuel in tank" number - and was not reflected by the analog gauge.
This was confirmed by experience when I ran the generator and air conditioning all night and consumed no fuel. Since I knew the approximate bun rate of the generator, I simply subtracted that fuel from the digital amount shown on the garmin and all was still golden.
Yesterday, the pointer on my analog fuel gauge disappeared for an hour or so. I looked on the floor and it wasn't there - but no problem, an hour or so later, the pointer came back in approximately the right place.
Is there a mechanical sender I should replace? If so, how do I access it? The inspection opening just to the starboard side of center about 2' inside the door has nothing resembling a fuel level sensor that I can see.
No big deal, the digital instrument is preferable, I'm just curious.
