Thanks for everyone’s help with build photos. In particular I noticed how much cleaner wiring and plumbing systems are in Kismet boat than in my R25. Seems wiring was standardized for a larger boat as there are “service loops” everywhere in my boat. If wiring and plumbing were diarrhea, my boat has a bad case- way too much everywhere! The original request was based upon finding out what was beneath the plywood in the starboard lazaret compartment. Since then, I have discovered that you can get the heater out without cutting anything. Well not obvious, but you can pull the heater back to the forward part of the lazaret, prop it up on one of the central stringers, then lift it and rotate it on its axis 90° and it will just barely clear and lift out. For anyone with this heater this is valuable information. Thanks again for everyone’s help.
Swims with Tuna
