DennisL
- Aug 11, 2025
- Seattle
- R-25 (Outboard)
- Nancy Ann
Hi There,
3 questions for the group! First one is my boat is in Shilshole Marina. Its a 2024 R25 OB and Im hoping to use the boat all winter long. I saw some threads about cutting your Pex so you can isolate inside water and outside water to outside shower for winterization - I was wondering if anyone with a similar boat has run it through the winter and could help explain to me what I should be doing to be prepared? I purchased a nice dehumidifier and small marine heater for the boat to leave onboard and running while on shore power, but I want to make sure Im covering all my bases and not messing anything up.
Second question: Anchor. I would like to replace my anchor based on the threads Ive seen around more confidence while anchoring. It seems the Rocna 10 is the most recommended - but my question is will it fit on the R25? The shaft of it looks a bit long but Ive not gotten the tape measure out to confirm. I dont want to create a massive project, just wanted to get a bit of a bigger anchor onboard.
Third question:
Does anyone have any tips for adding locks to the Lazarettes onboard? Likely not critical, but I am hoping to store an little outboard for the dinghy in there and would love to have it locked up. Worst case I can mount something inside the compartment and lock or cable inside, but id much prefer just locking the entire compartment!
Thanks so much!
Dennis
2024 R25OB
Nancy Ann
Third question:
Thanks so much!
Dennis
2024 R25OB
Nancy Ann
