peterd@btsi.tv
- Jun 12, 2021
- C-248 C
- FMLT2537J809
My first effort at winterizing the R25. Probably pretty safe area (North Texas) but we got hit hard last year. The Engine, washdown, and head all easy to do since I have a flush fitting. After shutting the thru hull valve, I just fill a bucket modified with a hose fitting at the bottom with antifreeze and run it thru these systems. My problem was the generator and A/C pump. No flush fittings and very hard to get to the inlet hoses to add one. So I bought an extra Jabsco strainer cover, drilled and tapped it to 1/2 " NPT and installed a male hose fitting. Now when I need to flush all I do is shut the thru hull, remove the original strainer cover (these are fairly easy to get to), replace it with the modified cover and connect to my antifreeze bucket. Works like a champ! My boat is on fresh water but the same trick would work for flushing out salt water when taking the boat out of the water.
