baz":150qmj8f said:
Submariner":150qmj8f said:
I get asked a lot about the LE, with its LFP setup. I'm looking to put out a video all about the LE electrical, and compare that to the NW edition.
Looking forward to this.... when ?
I'm seriously looking at using the R25/OB LE with the Lithium-ion battery option for my PNW adventures, but have the concern it's A/C heat mode creates a lot of moisture inside the boat. Now trying to figure out a solution for this.
I've already started putting material together for the electrical overview video. I'm working on drawings and such to best illustrate how it all works. I'm also working on getting onboard an LE, so I can get some photographs of their LFP installation. I have a few pics others have sent me, but I need to crawl around in one. Hopefully, sometime before the end of March we'll have a video to publish about this.
I would also note, it is possible to upgrade to LFP after the boat's been purchased (after-market upgrade). The factory builds boats. If every boat were 'custom', it would take them a lot longer to build them. The current wait for a boat today is a year, I'm told.
Since we boat in the Pacific Northwest, without any plans to boat in a hot climate, personally, I wouldn't want the LE for LFP if it meant I had to get the air conditioner. We use our Webasto diesel heater a lot.
As far as moisture in the boat goes, sleeping on the boat with 3 dogs and 3 adults creates more than enough moisture of its own. We've found 2 ways to deal with this.
1) Vacuum Squeegie. (Start at the 11:20 mark)
https://youtu.be/toxrIbleeVA?t=686
2) Get a small portable USB powered fan. Stick it on the port side, pointing towards the front window, put it on low, and let it run all night circulating air.
