R25OB or R23OB questions
trailertrawlerkismet
(2022) Kismet
We need some advice from R25OB and or R23OB owners who have experience/knowledge with 3 items:
1. Have any of you installed an Airhead Composting toilet on your R25OB or R23OB? Is so tell me of anything problematic in the install.
2. Those of you that have the cockpit sun/sunset shade option, not the Bimini, do or can you cruise with this set up or should it be stored between longer cruises?
3. Can you tell me the make and model number of the toilet that comes standard? I’m wanting to obtain measurements to compare against ?
As always thank you for taking the time to assist.
Jim F
Bumping this post up. I have gotten answers to 1 & 3 but I’m still in the hunt for someone to answer number 2. Does anyone cruise with the sun/sunset cockpit shade up ( not the Bimini in question), or have you found it better to stow away during water traveling?
Jim F
We have the Bimini and the sun shade, but I have yet to unpack the sun shade. Here it is in the factory packaging, though with a yardstick for comparison.
I would not cruise with it up. Not at 20+ mph, anyway. Appears easy enough to deploy and remove, though. Cave storage would about the only option on our R23.
I have run with the shade/rods deployed numerous times. I make sure there is no slack in the shade and always keep it below 20 kts. There is reduced visibility to stern so I always have crew check before altering course.
