R29 S fuel tank location and sender unit access
jimbeam
C-248 C
FMLT2545G708
waite & sea
Bad sender unit and need to know how to access it. Possibly want to replace fuel tank also. Old. Location and access to tank
We recently had an issue with fuel gauge reading oddly and tracked it down to a problem with the connection to the gauge as opposed to a problem with the sending unit. Gauge reads resistance to ground and should read 30 ohms full and around 240 ohms empty
I've heard that the senders are pretty simple devices and it i rare to see the actual sender fail. Usually it is a wire or connection
