Subject: R29's fwd and aft periodic auto operated bilge pumps
On my 2019 R29 CB Northwest Edition there are two bilge pumps in the engine bay. One is under the exposed prop shaft and stuffing box that drips water (aft one) and the other is fwd of the engine's front face and slightly aft of the rear cabin wall (fwd one).
Both of these pumps are operated automatically every 2 to 2.5 minutes. The idea is that if water is at a level the pump deems to pump out, the pump will continue beyond it momentary operation and pump out the water, down to some level where the pump deems as being OK.
The way the boat sits in the water, and if water is in the bilge, the water will be at a higher level in the aft bilge pump's area, with little water (if any) under or at the fwd bilge pumps location.
This aspect means that unless there's buckets and buckets of water in the bilge area under the engine such that water is present under the fwd bilge pump, the fwd bilge pump is rarely (if ever) used effectively. Thus, its periodic auto operation is somewhat of a waste of electrical resource and possibly unwanted wear&tare on the pump. To me, it would make sense for the fwd bilge pump be the kind that will only operate if water is in its area and needs to be pumped out.
