R29S Thruster Battery
Dave2016R29
C-30 S
Rock Lobster
Does anyone know what systems run off of the thruster battery for R29-S? I know it runs the thrusters and is the starting battery for the generator. Any others? Engine hatch? Automatic bilge pumps? Carbon Monoxide detectors?
Thanks.
Most likely the windless. Ranger wiring can change at times. Why not turn off the thruster battery and see what does not work or disconnect the positive cable. The bilge pumps and co detector are usually wired to stay on all the time and will be wired before any of the battery switches, hence the cable disconnect when searching. I would think you should have locations of these fuses in a wiring schematic.
