Captain Pat
- Jan 20, 2017
- C-302 C
- SLOW RIDE
I am the new owner of a 2015 R31S. above 3100 RPM I got a high water alarm. I lifted my engine hatch to see water spraying out between two different colors of metal that bolt together and are around the prop shaft just behind the engine going to the prop. Below 2100 RPM no water leaks into the bilge. Above 2100 RPM water sprays like crazy and appears to be coming from in between these pieces of metal that are silver and brass colored with 6 or 8 bolts connecting them together. Can anyone tell how I might correct or have this corrected? My Tug is at Burnt Store Marina in Punta Gorda FL.
Thanks, Pat
Thanks, Pat
