Ranger R-27 - EOM Motor Mounts for Yanmar 4BY2-180
JVCypress
C-26
FMLR2515K112
Sequoia
Time to replace the motor mounts on my R27 Tug powered by a Yanmar 4BY2-180 Engine. Wondering if anyone has identified an alternate OEM compatible motor mount to replace the stock Yanmar mounts. Thanks in advance for your input.
You're looking for the Silent-Mount SM-1609-45 and SM-1609-55. I found them at BANCROFT WESTERN SALES in North Vancouver.
I also found them at Mission Sales and Supply in Texas.
2 @ 17/1609/1-55 (front)
2 @ 17/1609/1-45 (rear)
Plus adjuster studs:
4 @ HAD16-20
Hi,
See here for my experience replacing the mounts on our 2011 R-27 (Yanmar). I replaced with the same "Metalastic" mounts that came out. These were far less expensive than the Yanmar mounts and as far as I could tell were the same parts. Got them from here - https://www.missionsupplyonline.com/Parts/metalastik-cushyfloat, same part numbers as listed above.
I would highly recommend adding the spacers under the mounts to keep them out of the water that tends to pool under them. It's been over two years and not a spot of rust on the new mounts.
good luck,
Brendan
What is the time interval that you are replacing the mounts?
Thank you.
Hi.
What is your plan for replacement? Will you remove the engine or do one mount at a time?
Hi.
I developed an oil leak and ended up pulling the engine. Actually not very difficult 1.5 hrs to remove and everything becomes very accessible.
