Doug in Williamsburg
- May 3, 2009
- C-248 C
- FMLT2529J809
- Carol B
Andrew, I am in the process of upgrading the anchor on my new Ranger Tug 25. I have no complaints about the anchor included with the boat as it is a good day anchor and satisfactory in light winds. Kudos to the factory for including 25’ of chain.
The claw anchor sets and resets very quickly, but has a history of slowly digging a trench in the seabed when compared to other plow-type anchors of similar weight. Therefore, it is not the best anchor for a sound night’s sleep while cruising.
At 5,750 lbs without gear, the Tug 25 is heavy for its length and requires an anchor one size larger than the 13-14 lb plow-type anchor many manufacturers include with the average 25’ power boat. My concern is the horizontal load on the anchor when caught in a blow.
If I have to select a heavier anchor, I am considering a 22 lb Delta or Rocna (they both have the same form factor) or the 26 lb Quickline Ultra. Can you advise regarding the compatibility of any of these with the bow roller on the Ranger Tug 25? I want to be sure that the anchor will stow securely in the bow roller.
Thanks and best wishes,
--Doug in Williamsburg
Ranger Tug 25 "Carol B"
