Since we purchased our RT we have been plagued with clogging of the raw water hull strainer by green leafy algae causing the engine to overheat. We do our boating on the Chesapeake Bay out of Cambridge, MD on the Choptank River. The slotted hull strainer provided by the RT factory seems to be a magnetic for this algae. In addition there is no way to cleanout the factory hull strainer without removing the boat from the water and disassembly of the raw water intake components.
We decided to modify the engine raw water intake by using a hull strainer typically found on the Chesapeake Bay. Also in removing the factory parts we found that the factory hull strainer was 1" ID while the engine plumbing was 1.25" ID. The new raw water intake uses a Groco APHS-1250-3 hull strainer with cleanout access door and an 1.25" ID thru hull. In addition, inside the boat, we replaced the 90 deg elbow on top of the ball valve that directs the raw water plumbing into the internal sea strainer with a "T" fitting. This "T" fitting allows for cleanout of the hull strainer from within in boat and a side benefit provides an easy connection to do fresh water flushing and winterization of the engine.
See pictures in our album.
