I have my Gallery Marine mechanic at my R25 Classic as I post this. The access to the oil line is absolutely incredibly difficult. Both beauty plates HAVE to be removed along with a large metal pipe that traverses left to right. Even then, access to the lower oil line's lower banjo connect is nigh impossible. I laid on my belly shining a LED light through the circular hatch for the fuel shutoff valve to help guide the mechanic's socket onto the bolt head holding the lower banjo. This took close to 5 mins and when the bolt was released the mechanic had to carefully extract the bolt by hand. In this process the existing copper washers dropped away into darkness somewhere.
At this point some 1.5 hours had been consumed.
Whoever posted that paper clips and string were needed was not joking as getting the new copper washers in place is going to be a huge challenge.
I will post back here after more work has been done along with some photos.
Update...a few hours later
Well it's all done.
The new Oil Sensor line was installed and it took almost 4 hours, and that was with me helping at times. This job really does require a second set of eyes, AND a straightened wire coat hanger...
😉 ...wire coat hangers are hard to find these days so I shall guard mine carefully.
1) I helped in telling/directing the mechanic when his socket was on the head of the bolt securing the lower banjo heads. I had to lay down on my belly with a LED light pointed at the lower banjos to do this. The LED light was shone through the circular hatch that exposes the fuel shutoff valve.
2) Placing the new copper washer between the engine and the first banjo was very very time consuming and the mechanic's patience was severely tested and he almost gave up with many grunts and groans until I suggested he use my trusty coat hanger wire (one used by Andrew a year or so back to unplug some seep holes for me) to place the washer correctly. Plenty of blue grease was used to hold the washer in place. Once that was done the bolt holding the two banjos to the engine was inserted and then I again helped/directed the mechanics socket onto the bolt head. In this process one washer was lost to the darkness of the bilge and Yanmar does not provide spare copper washers with their oil sensor line replacement kit.
Given the above and to be fair, this repair process really does require TWO people at times.
After the above the job went quite quickly and the black metal oval pipe that transfers the turbo's compressed air to the intake manifold could be re-installed.
Before installing the beauty plates the engine was run at about 1500 rpm for 15 minutes to ensure there were no oil leaks etc. It all looked fine and everything was replaced.
I give many thanks to Gallery Marine for sending out such a pleasant mechanic to perform this repair task.
They should equip him with cameras in his finger tips to make the work easier... :roll:
The mechanic said afterwards that without the wire coat hanger he quite likely could not have performed the work. Thanks Andrew for leaving me the wire coat hanger from the 2010 Bremerton meeting.
The only negative really, after all this is -- my R25 is now heavier by the weight of one very small copper washer. :lol:
Here are some pics I managed to capture during the 4 hours...
The new Oil sensor line provided by Yanmar
The new Oil sensor line provided by Yanmar showing closeup of the 5 copper washers that were included
Closeup of the banjo end showing the hole suppling oil/pressure to the oil pressure sensor
Sheafing covering a portion on the new oil sensor line - presumably to protect the line from being worn through when in contact with metal parts or maybe simply to provide some stiffness to the line.
Labeling info imprinted on the new oil sensor line
This is the old oil sensor line that was replaced by the new one. The main difference is the new line is all rubber hose and has no metal portions. I presume it is the metal tubing used in the old oil sensor line that fails in some way -- a severe break, a small crack, etc -- caused by vibration shock or maybe fatigue over time. It's hard to believe this metal tube used in the old oil sensor line would/could fail under an oil pressure of 80 psi when first starting the engine. I asked the mechanic about this and he had no good answer except to say "over engineered". :roll:
The next 5 photos were taken as the mechanic went about doing the repairs...
Note the long coat hanger wire to right of mechanic's head...
