DMD3":2lply4ph said:Dashcams work great. Simply stick on rear window and supply 12v power via USB charging port. Download the app to your device and wirelessly connect to the camera, also records to a memory card. Most have live view feature...
Here's a Garmin unit as an example: https://www.amazon.com/Garmin-Key-Sized ... R22DV?th=1
Severum88":16usreda said:The old Garmin VIRB cameras are plug n play wireless with my 7612 chart plotter on my 2016. I am using one as a bu camera with reverse image.
Severum88":39p10lj9 said:The old Garmin VIRB cameras are plug n play wireless with my 7612 chart plotter on my 2016. I am using one as a bu camera with reverse image.
Severum88":2l7z6rva said:It s mounted on rear cover over the cockpit to pilot house door. Seasucker. Reverse image setting is directly on the 7612.
