Recommendations for first Ranger Tug?
Brahe
Hey! I'm a new Tugnut, based in the Puget sound.
I want to get a Tug, probably a ranger tug, for trips to the San Juans and north along the inside passage. Bringing along friends and family.
What Ranger Tug do you recommend? What to avoid? I grew up with sailboats, not powerboats.
I'm obsessed and I can't get over owning a tug. Tug nuts.
Are you going to tow it or moor it? Inboard or outboard? How many friends and family? Go to the boat show in a few weeks with those answers in mind.
We love our 2023 R27OB! We converted from big boat sailors and often ponder why we didn’t change sooner.
We cruised the Maine coast from Marion, MA in 2025 and will be cruising CT/RI in 2026. Our big trip will be to FL and back starting in 2027. For us the R27OB is a great platform.
Having been boaters for 40+ years, we learned that boat choice depends on one’s boating plans: what does one plan to do on the boat.
It is probably more easy to buy a bigger boat than normal usage requires. However, it’s a personal decision.
The Ranger Tugs lineup seems to have abundant choice and possibilities. Some start small and work up to bigger as skills and needs expand.
We have been very satisfied with our R27 OB. Our only question is why we didn’t go this way earlier!
Excellent questions!! Let me add one big one? What’s the budget? If you’re looking at new and want a diesel then they start at the 29 and are priced accordingly. What about pre-enjoyed?
The biggest determinate in deciding which boat to buy is to be honest as you can about the intended use and expectations. For us, budget was a big factor. The 23 hit 90% of our requirements so that’s what we ended up with and are extremely happy with it. Accepting the limitations of a smaller boat, we don’t try to “shove 10lbs of $h!t into a 5lb bag”. Go to the boat shows, look at as many different used ones as you can, all while being honest about your priorities. To me, looking is half the fun…
Prior suggestions are all good. First big question for me is: Where will you keep the boat? We have always been trailer boaters for the last 45 years because there is not much water where we live. Mooring slips can limit your possibilities and make trailering the best option. If trailering, how big is the garage or parking space that you have to keep it in? Be realistic about your budget, both $ and amount of time you will use it. Buying smaller and moving up is not the worst thing to do. We had a few Sea Rays in the 23 - 25 foot range prior to our first Ranger Tug, a R25SC in 2015. Loved that little diesel and trailered it lots but wanted to go to a ten-foot beam before we got too old to get it on and off a trailer. When we ordered our 2021 R29 S it changed the storage issue which added another $100,000 to the budget and we don't trailer it anywhere near as far as the smaller boats, although some folks do. It is a great boat and fits our needs for the time being. When it no longer works for us, we can always go bigger or smaller. The outboards work well for the smaller boats, but fuel consumption advantages of diesel (also about $1 a gallon less expensive than gasoline at the marina) are significant in the larger boats (that said I have always been of the opinion that if you have to worry about fuel costs you bought too much boat for your budget).
Boats are all about compromise and trade-off's. Everybody boats differently. Two different families owning the same boat may have very different needs which makes it hard for me to give you a specific recommendation.
We own a R27-OB and took it to SE Alaska (Glacier Bay) from Everett. We lived onboard for 55 days with 3 adults and 3 dogs. Many have told us that we need a bigger boat, yet we don't. Our boat is plenty roomy, for us. But we aren't everybody.
When shopping for a boat, consider what can't be changed once purchased such as the hull (size of the boat), and the engine (how fast or slow are you comfortable cruising).
The outboard powered boats cruise around 25 knots. The inboard powered boats cruise around 12 knots. This is significant in that a trip from Everett to Roche Harbor is either 3 hours or 6 hours of cruising. To some, it's about the journey as they have the time. To us, it's about the destination as I have less time. I still work, but can't work from the boat underway, hence, why I went with the outboard. Fuel expense will be different also. The outboards will burn a lot more gas as a trade-off for less time cruising, and will get to the destination much quicker. The inboards are often ran at 6 knots and sip fuel, resulting in less money spent on fuel.
Some friends of ours in our yacht club, a sail boater, told me their annual fuel bill was $700. They cruise at 6 knots in their sail boat everywhere.
$700 is a months worth of gas for me during boating season. I generally spend between $4k and $6k annually on gas.
Also consider the size of the tanks, as they are often overlooked, freshwater, fuel and black water. For the waste water, assume 1 gallon per person per day onboard. We have a 30 gallon blackwater tank on our R27. With 3 adults that gives us 10 days before we need to empty the tank. The fuel tank determines the range of the boat. Our R27 has a 150 gallon fuel tank, keeping a reserve, I have about 200 mile range at 25 knots cruising speed.
Consider engine maintenance, whether you'll do your own or pay a shop. Outboards are easier to work on than diesels mainly because of their location, but require a haul out to perform simple maintenance. Inboards also require haul outs occasionally.
Are you going to trailer? The smaller boats with 8.5 foot beams are easier to trailer.
I hope this helps. Hope to see you out on the water!
This video might help. I compare the R27 to the R29, which is outboard vs inboard.
Ranger Tug R29S VS. R27OB​
We love our 2015 R31-CB (LE), purchased 5 years ago and new to us at that time. All questions above are important for you to answer for yourselves. Something to consider is the 6-4-2 rule for the R31 as far as being comfortable on the boat with guests. 6 for a party, 4 for dinner and 2 to sleep (comfortably). Good luck!
Great advice all around, and I completely agree with Martin: "Boats are all about compromise and trade-offs. Everybody boats differently. Two different families owning the same boat may have very different needs, which makes it hard to give a specific recommendation."
We are in the PNW area, and that's exactly what we experienced when upgrading from our small 18-foot Bayliner VR4 outboard bowrider (great for day trips but limited for overnighting) to something more capable for extended cruising. For us, the decision took 2+ years of thorough research, countless boat shows and youtube videos. I created a detailed spreadsheet of features, marking each as "must-have" or "nice-to-have." Our shortlist boiled down to:
  1. Cutwater C-30 Sedan
  2. Ranger Tugs R-31 Sedan
  3. Ranger Tugs R-29 Sedan
In our opinion:
  • The Ranger R-31 has the most spacious and inviting salon.
  • The Ranger R-29 has the sharpest exterior styling.
  • The Cutwater C-30 has the best head/shower compartment and master stateroom. My wife is claustrophobic, and the C-30's five portlights and two overhead hatches made a huge difference. The beefy Volvo D6 also appealed for its performance.
We flipped opinions several times along the way, seriously considering express cruisers, full trawlers, sedans, new vs used, boats with 20+ years old, diesel vs gas, inboard vs outboard, boats from various builders. It was a big investment of time, but well worth it.
We've now owned our Cutwater C-30S for 9 months and are still in the honeymoon phase. It's been fantastic for our cruising style. That said, your priorities will point you toward the right one.
Happy boating, and best of luck with your search!
Ir hasn't been mentioned yet but on the larger models you will have a choice between a sedan or a command bridge. I prefer the look of the sedan but ultimately was talked into the command bridge and I would definitely go that route again. The extra visibility from up top, especially in even moderate chop, makes it much easier to spot logs, crab pot floats, etc.
My 2025 RT29 is for sale. 74 hours.
All the Ranger Tugs are very solid boats, but with very specific tradeoffs. The biggest tradeoff is money. As @Submariner points out, it’s not just the cost of the boat but the fuel. And insurance. And storage/moorage. You won’t go wrong with any Ranger Tug or Cutwater you decide on. Many of the owners are on their second or third one. They started with one and decided to go (usually) bigger, or occasionally smaller. Start with your budget, and include fuel costs, insurance, maintenance, and moorage. The R-23 is relatively inexpensive, on all counts. At the other end, the R-43 has two engines to service and feed with diesel, and moorage alone on that can cost as much as a payment on an R-23 depending on where you put it. Figure out how much is reasonable to spend. There are great used ones to be had too for a bit of a discount. I’m not trying to sell it, but we have a 2024 R-25 on the market right now, for instance, because we’re going bigger.
Second, figure out what you want to do and how much comfort you want. If there are two of you, the R-23/25/C-248 are probably going to work out OK. You get a little more privacy in the 25/C-248 than in the R-23 with the enclosed head in those boats. If you add children, you can store them in the mid berth but you probably don’t want to put adults there for any length of time. If you are cruising with four adults, those boats get really cramped, and if you are staying overnight with four adult-sized persons, you should be pretty good friends first. If that’s what you want to do, and you can spend the money, the R-27/C-288 will be a better option, although still a bit cramped for overnighters. If you’re used to sleeping in a cot on a navy boat, you’ll probably be OK, but if you want a little more comfort, probably should try to go bigger.
Then there is cruising speed, like @Submariner said. No amount of fuel will allow an R-29/31 to get to the San Juans from Seattle as fast as an R-23/25/27. If you’re willing to spend the money on it, however, you could do that on an R-43. If you’re used to doing 8 knots on a sailboat, and happy to keep doing so, the diesel boats are economical and a great option. If you want to cruise the inside passage with family, in comfort, you may want to look at an R-31. The mid berth is usable and has a separate head, and it’s a bit wider. You’d probably be cruising at 11 knots or so though. If you want to do that at 25, you’re looking at either the R-27 or an R-43, or a C-288/32
If you can specify a little more what kinds of things you want to do, and the budget you want to stay in, several people here are happy to give you better answers. The Seattle Boat Show is coming up at the end of the month and would be a great opportunity to see the boats, ask questions, and even meet some of the owners who will be there. @abastos has some great insight on the basic differences, but to get more advice, you need to ask yourself some more questions such as:
1. How much are you interested in spending on the boat? How much on fuel/moorage/insurance?
2. How many people will you have on board most of the time? How many max? How often?
3. How fast do you want to go getting there?
4. How long do you want to stay away from home?
5. How long do you want to stay on anchor or away from a marina?
6. What else will you do on the boat? Fish? Crab? Kayak?
7. Do you want to be able to trailer the boat?
8. Any small things you want, like a dual seat at the helm?
9. Anything specific you absolutely do not want?
10. How important is a more full-featured galley?
Others can probably add some additional questions.
I'm going to have to agree to disagree with you there. Ha! 😀
Going from a sail boat to a power boat, here's a good overview of what to expect in the ways of cost of boat ownership for a powerboat. This is based on the R27-OB, but will give you a good idea on the diesel inboards as well, as their costs will be similar.
Cost of Boat Ownership of a Ranger Tug R27
Plus, when it's a beautiful day, nothing beats piloting from up there!
The same boat will handle differently with an outboard than it will with a diesel.
We love our 27-OB. The right size of me, the admiral, and our 10 year old. Also, its still small enough that I can single hand it if I need to. Maintenance is easy, and lots of vendors who can help when you feel out of your depth.
