Removal of cockpit seat?
palle
R-21
Hi, I need to get to the area below the cockpit seat to fix a leak. I know the seat can be removed to give access. Does anyone have step by step instructions on how to remove the seat. Thank you.
(1) pull the back cushion out of the seat ( Its not fastened, just a tight fit)
(2) Remove the two lower 3/8 bolts that work as a hinge. Turn the bolts out the nuts are welded to the bracket. When the bolts are removed the aft seat comes off.
(3) Unscrew the front panel and remove ( made of starboard)
(4 Unscrew the storage lid that is under the seat and remove ( made of starboard )
(5) Unscrew the storage pan that fits into the seat recess lift out and remove.
The access to the aft area bilge will look like this when completed.
I must have deleted the other photo's. I unfortunately ran out of space in my Album.
Many thanks for the clear instructions Brian, so easy to follow. Very much appreciated.
