RobMcClain
- Sep 29, 2013
- PNW
- C-30 S
- FML30C02J122
- Freedom 3.0
I have a Cutwater 30 equipped with the Force 10 propane stove & oven. I need to remove the unit briefly to access the area behind it. Has anyone done this, and if so any words of wisdom to provide?? I need to replace the propane sensor that is in the cabinet under the oven and I cannot access the wiring harness as the wires to the sensor are secured in some manner. I’ve been advised by the factory to remove the stove/oven, and that doing so will provide the needed access. I’ve also been told it is a relatively easy job, just one that requires cautious methodical hands. I just curious if anyone has done this?
Rob
Rob
