Hydraulicjump
- Feb 10, 2011
- C-30 CB
- FMLT2911F415
- Non-Fluid Motion Model
- Necky Looksha VII, Liquidlogic Remix, Jackson 4Fun
- La Barka (2015)
My poor tug died on San Francisco Bay week before last and had to be towed back to the dock. Here are the symptoms:
Ran fine for an hour or so at 1800 rpm. When I went to speed up the engine lost power and the check engine alarm came on (no codes, just check engine alarm). It would restart and idle fine, even run for a bit, then lose power and die, with the check engine light and alarm. This got worse and worse until it gave up the ghost and had to be towed. After a few days in the dock I started it up and it runs fine at a range of rpm's, but not under load (I didn't take it out....too chicken). Filters have 90 hours on them and these symptoms are not consistent with clogged filters (since they would stay clogged). No fuel leaks as far as I can tell, so I doubt that air is getting into the lines.
After lots of conversations with local mechanics and the internet, the suggestion is that I may have a clogged screen on the fuel pick up. The goal is to pull the pick up out and get rid of the screen, since the primary and secondary filters will handle the gunk just fine.
Any advice on pulling the pick up out?
Jeff
Jeff
