jimbeam
- Aug 21, 2019
- C-248 C
- FMLT2545G708
- waite & sea
When removing the refridge, can you just pull it out and disconnect the lines? Need to get behind it to see if i can get at the hand rail to install backing plates since the screw holes developed cracks from stress put on the hand rail. I may have to cut an access panel to get back there on the port side as well. The liner makes it almost impossible to get at port and starboard sides to check things like the hoses Etc.
Jimbeam
Jimbeam
