removing refridge r25
jimbeam
C-248 C
FMLT2545G708
waite & sea
When removing the refridge, can you just pull it out and disconnect the lines? Need to get behind it to see if i can get at the hand rail to install backing plates since the screw holes developed cracks from stress put on the hand rail. I may have to cut an access panel to get back there on the port side as well. The liner makes it almost impossible to get at port and starboard sides to check things like the hoses Etc.
Jimbeam
On theR25 Classic, you have to remove the fridge door to have enough room to remove the fridge.
The R-23 and the R-25 both have the same size beam. I was able to remove the fridge from my R-23 without removing the door. I remember it not even being very tight. There was plenty of wiring in the back space to slide the fridge out of the way.
Karl
Hi Jimbeam,
As already mentioned, you will have enough room to pull the fridge to get at other things. You should have enough wiring to set it off to the side without disconnecting it, but it can be disconnected if necessary. Hope this helps.
Cheers,
Ralf
On my 2008 R25, I had to remove the door to get the refer out. Furthermore, I had to remove the cabin door and frame in order to get the refer out of the cabin. Good Luck!
