Removing thruster propeller
Jfrano
R-29 CB
June Sea
Replacing thruster anodes. Also trying to take the thruster prop off....what’s the trick?
What I have done is take a piece of wood about 1"x1"x 2' or so and gently tap against the hub from the opposite side. Rotate the prop as so you do this. It should pop off, then apply some grease to the shaft before re-installing, this will help with removal next time. A Sidepower representative gave me this advise a few years ago and it has always worked.
A plumber's basin wrench is great for removing the anodes.
For then anode, take out the bolt with the right-sized allen wrench and then use the allen wrench, stick it in the hole in the anode for the bolt, and use the wrench to leverage off the anode (they often get stuck and this is an easy way to get them off).
For the prop, I use a large screwdriver and slip the handle between the prop blades, rotate the blade until the handle hits the hub, and then take off the bolt that holds the prop in place. I've always been able to pull the prop off by hand, but tapping the prop from behind, as Brian recommends, would help get it off if it gets stuck.
I grease the shaft as well prior to re-installation and paint the props with anti-fouling paint (I do this every spring).
