Replacement vinyl hull white-stripe?
Almanac
R-21 EC
Fool's Mate
The white stripe on my blue colored hull on my 2021 C-28 was recently scratched up by a dingy floating at the dock. I'm considering how to repair the damage. Does cutwater have information on the vinyl brand, exact color, size that is used on this stripe? I'm considering replacing a section of the stripe or potentially the entire stripe.
I was considering removing a section of the stripe, potentially buffing out the scratches on the gel coat, and replacing a section of the vinyl. Any information on the stripe you apply would be helpful. If you can comment on repair advice, also helpful.
uc
If you have not found a source yet for your stripe McKenzie Spoor did my lettering and stripes on our boat when we bought it new as we did not like the red stripe it came with. He is in Bellingham and does good work. His email is design@bigbolddesigns.com.
Mckenzie also did my vinyl name and logo, I already emailed him about it, but I figured I should ask what the factory installed if they knew. I think I may also have to went sand and polish the gel coat to remove the scratches.
Prism Graphics redid my bootstripe when I had my haul out for the same reason, then it happened again 3 weeks later…. So annoying. 🙂
