JDubya
- Sep 30, 2022
- R-23 (Sterndrive)
- FML30C07J021
- Couples Therapy
Has anyone had any issues replacing their microphone on their VHF bridge-to-bridge radio? Mine is not working with either the old mic or a replacement that I bought. I'm wondering if anyone has done this before and found it to not really be a "plug and play" situation.
Background is, I bumped into the jack on my VHF handset and broke the outer plastic casing. Wires remained intact and I was still able to talk on it.
In researching a replacement, I came across the Garmin GHS-11 https://www.garmin.com/en-US/p/568161#devices, which is listed as compatible with my VHF-215 AIS radio. This seemed like a great solution to me compared to the standard mic, because I struggle to read the radio's display from up in the helm seat since it's installed below the switch row on the C-30S and is not in a great line of sight.
I swapped the mics with the whole system (chartplotters, GHC-20, etc.) off, and powered on with no joy. Google & TugNuts searches don't yield any advice specifically for the 215. I did find some firmware related solutions for connecting to the Garmin VHF-210, but the steps I found to solve that haven't worked for me. The instructions both installation and operator's manual are silent on connecting the microphone.
When I go into the system info and run the self test, there's a line that says "Mic: No." Powering off and plugging the old mic back in doesn't work now either, same results in the self test.
I verified there are no bent/broken pins in the connector on the radio itself. I'm just not seeing anything else that's obvious for this one.
Any thoughts or previous experiences are welcome. Thanks in advance.
