Nickc
- Oct 2, 2020
- R-23 (Outboard)
- FMLT2378C919
- Spirit
I finally got the replacement bow thruster gearcase & Propeller (about 1month). This is a follow up to question to those who have done removal/installation of R23 LEWMAR gear case
I am about to haul boat to replace/ install new gearcase and want get boat back in the water the same day. I have the elec.motor assembly out & confirmed that the 2hex screws holding the gearcase can be removed (ie not seized).
My question is;
1. does the old prop on the bad gearcase have to be removed to get it out the old gearcase?
2.after removing the 2 hex screws securing the gear case to the mounting saddle- can tapping the top of the old gearcase with a rubber mallet, free it up so it drops into the tunnel?
3.should I be concerned about the plastic gearcase mounting saddle on top of tunnel being damaged when I remove the old gearcase? If so has anyone sourced a supplier for this part (mounting saddle #552004- I searched w/o success)?
4.with a little marine grease -can I expect the new gearcase assembly to slip in the mounting saddle?
Any input/suggestions appreciated.
My question is;
