Reverse cycle heat
Jfrano
C-30 CB
June Sea
Having only used it a few times. While it does get hot, it also gets very humid. Condensation on everything! Does this dissipate?
I don't get humidity when I use reverse cycle heat. Might need to get the system checked.
I never had an issue with humidity in heat mode. However, If you are heating the cabin and it is cold outside there does tend to be condensation on areas not having a thermal break, such as the hatches. Also, using a propane stove will create a lot of moisture in the air, as does breathing.
