Les Blackwell
- Sep 26, 2016
- C-26
- FNLR25121617
- adagio
I have a 2018 Ranger Tug 25SC with a D3 Volvo 150 motor. I am not a motor person having been a sailor most of my life. I am getting use to this big motor however....I seem to need to fill up the cooling fluid tank before i go out each time. I remove the upper outlet fitting, then reach under to get the main tank opening. With a good light I peer in and most of the time it is empty. So I have a tall funnel and I fill the filling tank up. I have gone through six gallons of antifreeze or cooling fluid
I have had a volvo dealer check out my engine and there are no leaks. I do not see anything coming out with the outflow water from the engine and there is no fluid in the bilge. We've check the hot water header and the Webasto heater for leaks.
First, do any you RT have the same problem or concern? Is this normal? Where could the cooling fluid be going?
My next thought is to have the Volvo dealer do what is called a pressure check on the engine.
Any thoughts to help me? Thank you.
