hal4cal":1oa49leu said:
Groundings are usually the result of pilot error. I belive that a depth sounder is standard equipment on all Ranger Tugs. if not, make sure that the one you purchase has one. Then set an offset of 2 1/2 ft to 3 ft to allow for a margin of error. Continuously observe your depth soundings whenever your are in shallow waters and you should have no problems. To know whether or not you are in shallow waters you need to have a rudimentary understanding of how to decipher a marine chart. If you do not want to go to that much trouble you might consider an alternative means of transportation.
You did well for three sentences but even there left out "or have one installed". After that, you not only suggested introducing intentional error to the boat's instrumentation but wound up being a bit preachy and overly sharp in response to a legetimate question by the OP.
Bad data is generally worse than no data. The
offset to the sounder should typically be set so that the sounder reads depth under the keel. E.G. if your transducer is a foot above the keel the offset should be set to a foot. It would even pay to verify the offset by actual measurement since even the type of water (i.e. salt/fresh) the boat is in can make minor differences in the reading. Then, if you want 2 1/2 or 3 feet of "safety margin", the
alarm function should be set to the 2 1/2 or 3 feet. Of course, with perfect knowledge of water depth by possessing a "rudimentary understanding of how to decipher a marine chart" you might correct "upward" from the depth of the transducer to the surface of the water. Then at least you will know how much water you are in at what is typically chart datum of mean lower low water. Correct once or twide a month. I suspect the captain on the QEII may have relied on chart datum when he had his little problem.
I also suspect you have never traveled the inland waters where, at best, most charts show "water" and "land". I think knowing depth under keel is more useful there, too, and the real use of the chart is to locate yourself with respect to the towboat traffic when you hear them announce their positions.
I would even say, and I don't claim authorship, that there is a great deal of truth in the saying that "If you don't go aground once in a while you are not using your boat to its fullest capability." That being said, in most grounding situations the design of my R21 leaves nothing in great danger and I presume the designs of the 25 and the other tugs provide similar protection. I think the only significant damage one could incur would be to ground at high speed going astern. Not a likely scenario.
A couple other truisms are that if entering a strange anchorage it is better to enter at low tide than at high, and any time one is aground he should pretend to be scrubbing the bottom so others will think you did it intentionally.
