it4llc
- Oct 18, 2020
- Arlington, VA
- C-28
- FML28C17K920
- Gremlin
I currently have 3 Xtreme heaters running in my boat, 1 in the bilge and 2 in the cabin. (The 2 in the cabin may be overkill as I winterize the freshwater system and the A/C.) I don't winterize the engine nor the generator. Right now I have the heaters set to run from shore power. The marina where we are supposedly doesn't usually lose power (there, I jinxed it) but in the rare case it did, is there a way to run the heaters from the inverter/batteries, while simultaneously charging the batteries from shore power, such that if the power did go out, the heaters would continue to run?
If I set the power panel to run from the inverter, then I can't turn on the battery charger on the power panel to recharge the batteries from shore power, so assuming I've got this correct, I guess my question really is whether there is a way to have the battery charger draw from shore power apart from the power panel? The Xtreme heater specs say the normal operating current is 4 amps, so even running all 3, I should get 8 hours of run time before hitting 50% discharge on a 200Ah bank, which would last at least a day or two since the heaters don't run non-stop. That would afford some additional peace of mind in the event of a power outage.
