DBBRanger
- Mar 31, 2013
- R-25 Classic
- Still Crazy
Barry Cohen":3q6m5hyh said:R Baker: I used that fitting this past weekend to evacuate my fresh water tank and lines. It worked like a champ.
I blew out the storage tank, head and galley faucets, cockpit shower and hot water tank. Now there is no need for antifreeze in these lines. Saves about 7 gallons.
I have used that kind of fitting on my camper trailer before, but because of the way it was plumbed, I had to independently insure that there was antifreeze in the pump itself. Generally, the dockside water connector bypasses the tank and pump. It does do a great job in removing the water in the lines downstream, but not at the pump. Certainly one needs to insure that the pump is protected from freezing. Because the pump is not that easy to get to, I don't use the "blow out method" on my R25.
