AGLyme
“Sweetie” RT 31cb
- May 15, 2024
- Lyme, CT
- R-31 CB
- FMLT3129J213
- Just contracted to buy it, changing nm.
Re my 2013 31cb, Thinking/planning on removing the Sat Dome in the mast and to install a Weboost Marine system. I will replace the (2) TV's with essentially "smart" TV's which are effectively computer screens that will pair with my cell phone and onboard iPad.
The present TV reception is quite bad given that the equipment is old. I will lose the TV link to the Garmin Chartplotter but its a small sacrifice.
When I install the marine Weboost, I would like to re-use the existing/installed Sat Dome cabling. I believe the TracVision Sat TV dome uses either the RG-6 or RG-11 RF cable...according to current info on the internet, I will try to see if the cable gauge is actually written on the cable itself.
The plan would be to add cable to hook up with the WeBoost inside booster, which will be linked to the WeBoost antenna up in the mast where the TracVision dome was previously.
I am seeing both RG-6 and RG-11 cabling sold on the WeBoost website. So I am hopeful my re-use the cabling plan works.
Would also appreciate tips on where folks placed the inside WeBoost booster and electrical hookup. I think I am buying the 12v version. I am not smart when it comes to electricity or electronics... so go easy...; )
Thank you in advance.
