rick&sue
- Feb 5, 2014
- C-248 C
- FMLT2506J607
- POPEYE
This may be so obvious that I just can't see it....... But - I replaced the scupper flappers and the flap angles away from the sealing surface about 3/8 of an inch. If I turn the flapper around and mount it back in the tube, it is tight against the sealing surface. There is only gravity pushing water out of the scuppers, understanding that if I'm taking waves over the transom, there will be LOTS of water pushing through the scupper flap. I'm just not sure if flap should or should not be sealing against the sealing surface. Would appreciate your thoughts/experiences.
Rick
Rick
