Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
Martin, thank you for this second 'user perspective' video, the partner to your first 'data intesive' video. This second one helped me get a good sense for what living with one of these modified 4 or 5 blade props is like vs. my 250's 3-blade 'factory prop'. One observation you made in video #1 was the difficulty you had in getting accurate fuel burn (mpg) numbers off the Yamaha engine display. That's sure true for my 250. 1.2, 1.4 and 1.6 are the only numbers I've ever seen when at planing speeds; nothing in-between them. For those of us with the basic electronics package, do you have any suggestions for getting better real time fuel burn data? Thanks again for the time you have put into this project.
Thanks for watching! I'm glad you found the second video helpful. Plus, I think it's great when LaZina gets in front of the camera.
The Garmin Chartplotter USED to show mpg. In April 2021, a software release "broke" it. I dunno why or what. I've spoken with Garmin about this, as it worked for the first year we owned the boat. mph / gph = mpg, those numbers are available on the chartplotter. Today, you can get mpg on the chartplotter only if you do NOT have the Yamaha to N2k gateway installed. All the new boats (2023 and newer) come with a J1939 cable for the chartplotter and no longer come with a Yamaha N2k gateway. The J1939 cable plugs engine data directly from the J1939 network into the chartplotter and mpg can easily be shown on the chartplotter. For those of us running the Lenco Autglide (auto-pilot for the trim tabs), it requires engine data to operate (engine RPM, specifically), it requires that data via Nema2k, which is only possible with a Yamaha to N2k gateway installed. If you ran a J1939 cable and a Yamaha N2k gateway to get both to work, the Chartplotter would see two engines.
My setup is Yamaha N2k gateway, which means I get MPH ad GPH on the chartplotter, but no mpg. Which leaves the Yamaha display for their 1.2, 1.4, or 1.6... I've also seen .9 (bad bad number... Lol).
This has been somewhat frustrating for me, but something I've just learned to live with. That's why I illustrated that in the video. I look for 30mph / 20gph which I know is 1.5mpg. If the numbers are too far apart, I'll just do the math on my phone. MPH / GPH and get my mpg number while driving.
