Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
REVERSING A C?
Sub...fantastic analysis...thanks. Now, for you, or anyone who knows....fuel spend is not a huge factor for us - related to how we use the boat - which is primarily day boating. I mean less fuel is better but we will not recoup ROI if we gauge it on fuel spend. I like tinkering around and improving, and I like to "feel" any changes at the helm. My "feelz" are the pay off for us.
So regarding the 5 blade - the C 24 is a sumbiiich to back up. If current is running side to - even the yammy cranked full to the side and the throttle hammered - the stern will not respond. And TBH, even with no side current, it doesn't back up well at all.
I assume this is because A: the aggressive steps work directly against reverse thrust and B: the fulcrum effect of the prop being so far back with the bracket, etc.
I got a little relief going from 3 blade to 4....and I trim engine up so that less of the thrust is bouncing off the stern....but still not good. .I would like your theories on a 5 blade in this situation.
As well as your predicted impact on mid range acceleration and hole shot. (the 4 blade + SKR have already helped this boat a lot).
Better fuel efficiency means further range between fuel docks. I'm now at 200 miles on 120 gallons of gas, going against wind and current, traveling at 30mph. This is what I was after for off-grid cruising throughout SE Alaska. (Prince Rupert to Shearwater is 204 miles. Petersburg to Sitka is 175 miles). I couldn't do either of those runs on the 4 blade prop without a fuel stop or 2 days of slow-boating at 7 knots. The 3 blade prop could do it but lacked all the other features (hole shot, reverse thrust and mid-range cruising).
I back into the current all the time with the 5 blade prop. I have more control in reverse than I do forward. I run the boat in reverse a lot. I also rarely ever use my bow thruster as I'm able to maneuver the boat just fine with the engine and a suicide knob and the 5 blade PowerTech prop. The 5 blade prop is a better fit than the 4 blade prop I ran ever was, and is way better than the factory 3 blade prop, in every way.
I also want to point out, the prop's I am specifically talking about:
- Yamaha SWS II, 15.75x15 3 blade.
- PowerTech OFS, (Offshore), 15.25x15, 4 blade.
- PowerTech SCE, (Semi-Cleaver), 14x15, 5 blade, with the exhaust tube (Channel Surfing edition).
Prop size, and blade geometry are everything. Prop testing is part science and part trial-and-error.
