DreadKnot
- Jan 17, 2015
- C-28
- WN5090SB
- DreadKnot
We have a 2014 27'. We are in dry storage for the winter and have had shore power on and batteries charging. I still have power coming to the boat, but now the shore power indicator light on the panel inside the boat is not lit. I'm guessing this has been an issue less than 3 days since I just heard the alarm for the first time today. I checked connections and have power coming through the factory provided extension cord, as the blue indicator light is on. Battery levels indicate that the house and thruster batteries are good, engine battery has drained down. There is a horrid alarm that seems to be coming from the front bilge pump, assuming that is due to dead battery. I flipped the parallel switch to use the full bank to test to see if I could get the alarm to stop sounding and it did stop (no water in the hull - I checked and it would be impossible anyway since we are under cover). I cleaned the connection and reseated the shore power cord - still no power/indicator lights to the panel. With the parallel switch on for only 3-4 minutes, I got the engine bank to display 9, so the alarm stopped sounding for now. I checked for corrosion on batteries and they all seem fine. Not sure where to start the troubleshooting. I'm assuming there is a fuse for the shore power transfer? Help would be appreciated. Even though it isn't that cold, I'd like to maintain air flow and low heat to the cabin.
