Shore Power problem
pugtug613
Pugs Tug
My R27 has a problem. My shore power just quit working. Absolutely zero. The inverter still works and the genny. Is there a circuit breaker somewhere? I have 2 GFCI outlets, but right at the panel, the gauge is on zero.
On my R27 there is an AC breaker at the aft of the port locker (genset locker). I would check that breaker.
Curt
How old is your R-27? The newer electrical requirements have additional ground fault breakers right off the shore power.Take a look for that one it may have tripped.
My R27 is a 2012. I will go down to the boat this evening. It seems like a tripped switch to me. It happened when I was plugged in with the A/C going, lights, DVD and it was HOT. That A/C was cranking. Everything just went off. We were leaving anyway, so I didn't worry about it. Now, I tried to plug in last night and get nothing. I'm sure it's just a matter of finding the breaker and flipping it on.
Thank you Red Raven!
I lift up the genny hatch and what do I see? A circuit breaker switch.
Everything is right with the world again.
You are welcome! It is so nice when it works out to be a non-problem!
Curt
