captstu
- Nov 10, 2014
- C-248 C
- Shearwater IV (SOLD)
Hi, I was installing my new 2500 Watt inverter today. The process involves removing the shore power wire from the breaker panel, connecting it to the inverter "Line In" and connecting the "Line Out" to the shore power breaker.
In this way, when there is shore power present, the inverter senses it, turns itself into a charger, and all is gravy.
The Shore Power input is rated at 30 Amp and is typically connected to a 30 Amp protected outlet at the marina.
The inverter puts out a maximum of 27.5 amp and "consumes" most of the balance with its internal battery charger - at least for the first few minutes of charging.
All is good.
Unfortunately, the wire from my shore power plug on our 2010 R-25 was quite warm when I started removing it from the breaker. I examine the wire and was surprised to find that it, and all the AC wiring, was 12 gauge. On checking further, I found the wire was warm over its entire length! A fire waiting to happen.
12 Gauge wire is rated at 20 Amp maximum current. It just won't handle 30 Amp - or even 27.5 Amp - a value you are likely to meet or exceed when the air conditioning, hot water heater, and possibly a stove element are all working simultaneously. While such a load will eventually trip the shore power circuit breaker or your boat's master circuit breaker, it may burn your boat to the waterline first.
I don't know if Ranger still wires their 30 Amp shore power plugs with 12 Gauge wire. I suggest you check - I changed mine over to 10 Gauge as required - it is a simple change you might want to consider so you can sleep better at night.
Curious - in the inverter equipped boats provided by Ranger, is the inverter on the shore power circuit or the generator circuit?
All is good.
