it4llc
- Oct 18, 2020
- Arlington, VA
- C-28
- FML28C17K920
- Gremlin
I came onto my boat yesterday and the shower bilge was running non-stop. I looked at it and nothing seemed obvious in terms of problems. This one has the float switch, which was down. When I pulled the float up, the bilge actually sounded like it was working harder. From what I can find online, it is only operated via the float, so I am not sure why it would be running, then when I lift the float it would run even harder, ie I would expect it to either be on, or off. Pulling the fuse turns it off. Based on other posts, I'd think the switch was bad, except for that fact that lifting the float changes the noise on the pump. Does the pump have both the internal sensor as well as the external float, ie should I try cleaning the pump itself? This is on a 2020 C28.
