Shower Pump Fuse
Brian John
Kilmarnock, VA
R-31 CB
Shutter Speed II
So the shower pump quit working on the R-31. I looked for the fuse but could not locate one. On the R-31 Dash Fuse Block #2, left side 2nd fuse down is labeled Shower Pump, except there is nothing connected to this location. I do not have 12 VDC at the pump in the V-Berth (float switch works, pump is defective). I need to locate this fuse. I have checked all the fuse blocks and am at a loss for the location of the fuse.
#ranger tugs #r-31 cb
The location you described is where it should be. Are there no wires running to that fuse location?
