Side power thruster
Tugboat Bob
R-27 Classic
FMLT2726C313
Passion II
Does the factory have a special tool to remove the 2 Allen keys hiding the stern side power thruster to the transom?
You can buy it from Imtra. Here's the link:
https://www.imtra.com/products/sleipner ... tion+Tools
I didn't want to buy a special tool, so i used a very small/low profile 1/4" wrench with a 6mm hex bit in the closed end. I would recommend buying it after the amount of futzing I had to do to get the bolts on and off 🙂
I recommend buying two of the Imtra wrenches. If you back out the bolt too far on one side before backing out the other side the wrench can get jammed between the motor housing and bolt head. Since the wrench only ratchets in one direction there is no way to drive it back in to remove it. You will need to find another short Allen key to back out the other side to loosen the motor enough free up the first. Two keys solve this problem and make it so much easier because you don’t have to move the wrench from bolt to bolt which can be really difficult in such a tight space!
Curt
