Did you try removing the monkey fur panel in the cave ? Under the captain's seat? Once off, look straight ahead and the remote box will be facing you on the front mounting board. Remove the plastic plug to access the programming button.CaptT":31fuxh8k said:If it's like the 28 it's located almost directly under the thruster controls. Access is through the cave. It's in a tough position to reach, I used a plastic tipped screw driver to reach the button you need to press to pair the remote.
Hope this helps.
