Can the factory tell me the following things...
1) Size of the fresh water tank in gallons
2) Size of the water heater's tank in gallons
3) Does the the 'size' for 1) include the size of the water heater's tank capacity ?
4) When I fill the fresh water tank via the fresh water filler does water go into the fresh water tank and the water heater's tank ?
5) If 4) is true, and fresh water tank's capacity is 40 gallons and the water heater's tank's capacity is 6 gallon (for example) would this mean I could in theory pump 46 gallons via the fresh water tank's filler when both tanks are empty ?
Thank you. 🙂
Thank you. 🙂
