PlanetoSea
- Jan 13, 2020
- C-30 CB
- FMLT2913I718
- Plane To Sea
Heronboy":25f9g5o2 said:I would try removing the accumulator. When I installed my replacement pump (a variable speed Remco) I spoke with Remco directly. They where adamant that an accumulator NOT be used with their variable speed pumps. They discovered accumulators frequently cause issues with variable pumps. The pumps would constantly run or not reach full pressure.
Before you go thru the effort of removing the accumulator, you could also try fully filling the water tank. What you describe could also be a crack or split in the tank’s dip tube. If the tank were partially full and the crack was above it, the pump would have difficulty priming and reaching pressure.
Great advice and suggestions—thanks. I’ll give those both a try tomorrow.
