CaspersCruiser
- May 11, 2016
- R-27 Classic
- FMLT2709G112
- Cookie
My 2012 Ranger Tug R27 is the first boat I’ve owned that has had shore power. When removing the shore power cord, a few times this season I noticed that the plug was somewhat warm (but not hot) to the touch. Since I didn’t have a frame of reference of what was “normal”, I did some reading and research.
I found that shore power connections are a fairly significant source of boat fires. The typical twist lock style shore power connection has some problems ranging from insecure or inadequate connection to weather tightness. Some respected folks recommended a new style shore power connection called the Smart Plug (http://www.smartplug.com) that addresses these issues.
Installing a Smart Plug shore power system is supposed to be easy and the company has some good installation videos on their website. The screw pattern holding the inlet to the boat is the same for both style inlets so no drilling is required.
Today, I installed a Smart Plug shore power inlet on my tug. The inlet installation video shows the installer removing four screws and easily pulling out the existing inlet assembly with about a foot of slack in the wiring coming from inside the boat.
I was not so lucky. There was ZERO slack after I removed the four screws. Gaining access from inside the battery compartment, I traced the wiring to the shore power inlet and there appeared to be some slack available. What was preventing the slack from being pulled through the inlet hole was a 16 gauge wire hooked to the galvanic isolator by a ring terminal. I removed the nut securing the ring terminal and was able to pull about eight inches of the shore power wiring out the inlet hole.
I was anxious to see the condition of the existing shore power inlet because during my research, including right here on Tug Nuts, I had seen photos of scorched or melted components on shore power inlets. On my shore power inlet, there was absolutely no evidence of thermal stress on the plastic parts or wiring. The ends of the wires were clean, bright and shiny with no hint of corrosion.
I could have reinstalled the existing shore power inlet, but I do like the features of the Smart Plug so I went ahead with the installation. There are no special tools required and the wiring is very straight forward- just follow the colors, e.g., green wire in the green hole. If you can change a wall outlet in your home, you have the skills to install a Smart Plug inlet.
If you put a Smart Plug inlet in your boat, you will also have to change the boat end of your shore power cord. Smart Plug assemblies are sold in kits that provide the inlet and shore power cord end. Shore power cord ends are also sold separately so that additional shore power cords can be converted to Smart Plug configuration. And pre-configured Smart Plug shore power cords can be purchased.
A downside I see to making this conversion is that you must now have a shore power cord with the Smart Plug end on it to have shore power. You won’t be able to borrow a regular shore power cord and use it. Also, there is certain amount of risk of unintended consequences any time you mess with wiring, but there is really no way to check the condition of your shore power inlet wiring without fairly major intrusion. For me, it was worth it for my peace of mind.
