DDean
- May 6, 2024
- C-28
- FMLT2716G
- SkipperJon
Thanks in advance all. I’ve watched what seems like hundreds of hours of YouTube on this and have searched here - I think that I have a plan to do this but there are differences between the schematics that came with my boat and what I’ve learned, and I’m hoping to clarify some items.
I have a Victron smart shunt to install into my 2024 R27. I will try to attach the factory schematic.
I have three batteries in the port lazerette - most forward is the thruster battery then two house batteries.
Forward house battery (middle battery) seems to be the rightmost battery on the schematic.
Forward house battery has three 1G neg yellow connections, one being the neg bridge to the aft battery.
Another should be negative from the gnd buss (not labeled) based upon the schematic.
The other is a neg bridge to thruster batt. The neg bridge to the thruster battery differs from the schematic (which doesn’t show a bridge), I’m guessing (didn’t look while on boat) because positive isn’t bridged.
Aft most battery appears to be the left battery of the house batteries on schematic
It has two 1G negative connections.
One is neg bridge to forward house battery neg terminal.
One is unknown (not labeled) - likely from inverter based upon schematic.
It also has small yellow wire to ACR (auto charge relay).
Questions:
Is it appropriate to mount the shunt before the aft battery? Ie, have the battery side of the shunt connected to the negative terminal of the aft most battery?
I’m taking everyones guidance and putting all the non bridge 1Guage connections to the negative terminals on BOTH batteries onto a buss, and connecting that negative buss to the load side of the shunt.
Therefore, I would attach the suspected inverter neg and suspected gnd buss neg to new bus forward of the aft battery? This combines negatives when they came separately attached to each battery stock, which causes me to pause as I’m unsure why (aside from avoiding stacking) they are initially separated).
I think that I should leave the small yellow ACR wire on negative term of aft battery?
Martin spoke about a number of different loads to put into a negative buss in his video - I do not appear to have any of those connected directly to my batteries from the factory. I have just the two suspected inverter and suspected ground buss, the ACR wire and the negative bridges. I think everything drawing from house batteries is captured by the connections going to the negative terminals of the house batteries by physics, right?
Does it matter which positive terminal I connect the shunt to?
So if I put the suspected gnd buss and inverter on a new negative buss connected to the load side of the shunt and connect the battery side of the shunt to the neg terminal of the aft house battery, with the positive shunt wire connected to the positive terminal of the aft battery….is that correct?
Questions:
