Irish Mist
- Apr 25, 2012
- Orillia Ontario
- R-29 Classic
- FMLT2922K011
- Irish Mist
I finally broke down and got a portable freezer. Opens up a whole other aisle when we are shopping now. I can get ice cream and it is harder from our freezer then it is at the store. 🙂 It maintains 0 degrees Fahrenheit and will go down to -6 It is a real freezer with a compressor, runs off 110 or 12 volt. If you plug both lines in it switches to 110 when you have it automatically. 28 X 18 X 21 inches 60 lbs, made by Whynter. I have model 65. It can also function as a fridge if so desired... It can fit in the cave on the older 29's. I would advise getting the 45 which is slightly smaller. I found that a bit smaller would have fit easier in spots, but I thought I could use the extra space inside the freezer.
Here is a link if you are interested, Not real power hungry after it is down to temp.
http://www.whynter.com/productdetail/re ... eezers/308
