Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
in case anyone is interested in the this install - I mustered the courage last night to glue on the cup.
using the angle app from the apple appstore I could tell the angle of the hull in this location is 25 degrees so went with the max 22 degree angle markings - I dont have a manual inclinometer. test fitted the location to make sure I can get the sensor in the cup with the floor overhang in the way.
then
cleaned
sanded
acetone wiped
then liberal use of 4200 quick cure to mount the cup.
pushed down and then applied extra to overalap the lip of the cup and ensure a strong and watertight seal.
its not pretty but doesnt need to be.
4200 should cure in 24 hours
will test this weekend to see if this is sturdy and watertight before installing the sensor
then
cleaned
sanded
acetone wiped
