captstu
- Nov 10, 2014
- C-248 C
- Shearwater IV (SOLD)
Today there was no power to the key switch. No red light when I turned the key, no "ignition" in the menu on the Garmin display, and clearly no ability to start.
I removed the switch and saw 7 volts with the switch off and 0 volts with it on. Clearly, a dirty connection, blown fuse, or something similar.
There is 12 volts at the test point in the engine control module and 12 volts at the connect relay.
Where does the ignition switch get is power? I don't see a fuse or connection on the wiring diagram - and before I bridge the switch to a new power source, I'd like to find and fix the problem.
Thank you
Thank you
